Device already has a spoken
I'm attempting to expose a state variable as a motion sensor in Alexa. I've changed the name of the variable and the spoken several times. However, I continue to get "Device already has a spoken". I can expose the variable as a switch using the same variable and spoken names and Alexa accepts it. I have several other state variables exposed as motion sensors with no problems.
Thank you!
Thank you!
I believe you have another device with the spoken you chose.
Try to enter the spoken in the search box to find which device has this spoken.
I just discovered the problem. A human error no less! The variable ID I was trying to use was already used for something else. Problem solved.
Thank you for your response!
