pg3 missing directory
I have everything running on my eisy except pg3.
When I go to the web interface I get the following error:
ENOENT: no such file or directory, stat '/var/polyglot/node_modules/@universaldevices/pg3x/public/index.html'
As far as I can tell pg3 is installed and running.
How are you trying to connect to the web interface? If just typing in the eisy IP make sure you add :3000 to the end of the IP. So it shoudl be:   http://<eisy.ip.ad.here>:3000
Otherwise you can access it from IoX Launcher: (Selecting Polyglot V3 option)
If you can't access it how do you think you can tell it's running?
  http://<eisy.ip.ad.here>:3000 was what resulted in the described error.
Uninstalling / Reinstalling pg3 via the terminal and a eisy restart fixed the access issues.
I still have problems with the node servers, but it seems a lot of other users report similar issues, so being patient will probably solve a lot of issues over time.
Thanks for checking
