Create an Elk arm away widget - Not Working
I just tried this and it worked fine to arm the system. However I don't use this method, I created a program for stay and away which arms when on and disarms when off. I've actually thought about just creating a node for each arm status so you can just add the node as a favorite.
Sent from my SM-X808U using Tapatalk
here is the event log when I press the arm away button
It also creates this on the node server front
I have restarted the node server with the same impact
and this is the node server log
my user code is 90...a completely random number per instructions.  Please let me know if there is something I need to change
thank you
This can't be a random number, it needs to be a valid user code defined in your ELK system.  Personally I create a specific user code for PG3 so I know who is arming/disarming the system.
ahh - got it!   thank you.  To avoid this you might want to update the documentation to explicitly say on the ELK...then again I may the only one that didn't understand.
