iox 5.5.2 conversion
If I read the conversion announcement for 5.5.2 zwave, it doesnt mention the restore of Insteon to the Polisy / eisy
Is there a conversion process to follow before the zwave conversion ?
It is in the instructions starting at step 4:
Migrating from 994/Polisy to eisy
Note Z-Wave nodes are not automatically migrated: Note Z-Wave migration can only be done from 994/500 Series board
  1. Make sure the ISY994 is already upgraded to 5.3.4,
  2. The eisy OS should be at level 13.1 or greater. Just in case - Note the IP address of the ISY994 and the eisy.
  3. Backup your 994's Z-Wave dongle (Admin Console | Z-Wave | Utilities | Backup | Full)
  4. Backup your 994 (Admin Console | File| Backup ISY). Note where you placed the backup of the ISY994 it will be needed in step 7.
  5. Plugin the PLM to your eisy
  6. Restore the backup of the ISY994 on the eisy (Admin Console | Help | Restore ISY) from the location saved in step 2
  7. Log back in to IoX and make sure INSTEON Support is enabled (default username/pwd = admin/admin)
    1. If this is a new PLM, Restore the PLM
  8. If you have Z-Wave
    1. Make sure Z-Wave Support is enabled
  9. Reconfigure any software utilizing the ISY994 to point to the IoP (From Step 4), restart the other software, if necessary.
  10. If you have ISY Portal on your 994, follow these instructions to migrate your account, license, and Alexa/Google Home settings
    1. This will also migrate all node server licenses from your Polisy to eisy
  11. If you have Network Resources, please make sure you open and save each and every one individually
  12. Make a backup of your newly configured IoX.
Edited by DennisC
Added step 4
Good morning;
My eISY is on its way to me, should be around Panama right now!
I currently have ISY994 (5.3.0) with the Zwave 500 dongle, hooked up to PG2 on a Polisy (13.1). 100+ sonoff/Tasmotas (MQTT) and a slew of 5V Wired Z-Wave Aeotec Multi-sensor 6s. No PLM, no Insteon.
Over the last few days lots of information on this and the 5.5.0. threads. Thanks for all the input!
Question:
Does Z-Wave migration from ISY/Zwave500 to eISY/Zmatter (for powered Z-Wave devices) work now?
Cheers;
