Eisy- ZWave not working
I have the Eisy and Zwave/Zmatter dongle plugged in. Latest version of software for everything. When I try to add a Zwave device, Eisy does not recognize anything. It listens but never finds anything.
I have a simple plug switch and also a multisensor motion/temp sensor that I'm trying to pair.  Do I need some kind of a ZWave hub or something?  Things were working fine with my ISY994i
31 minutes ago, GJ Software Products said:
@bigDvetteIs that using the USB:  Z-Wave+ Matter module and not a Zooz 700?  I've tried everything and can't get it to work.  I have a ticket open with UDI and they told me a build is on the way.
I'm using the ZWave/ZMatter dongle. Not the Zooz 700
@bigDvetteWow!  I installed it, checked the Z-Wave checkbox, reboot & when you select Z-Wave on the menu bar it says no dongle found.  And if I press Migrate to Z-Wave it winds up in an infinite System Busy loop.
Did you try to remove before you add?
