January 10, 20233 yr Just upgraded to IoX 5.5.3 and did a Z-Wave synchronize update with interview on the ZEN16 and the ZEN17. The additional two switches were added to the ZEN16 but they aren't functional. Just shows a blank page for those devices. No ON/OFF etc. No additional inputs were added to the ZEN17 representing the dry contact closures when configured to have the inputs separated from the output relays. Just though I'd pass along this info. Thanks Gary eisy 5.5.3 Z-Matter
January 10, 20233 yr @garybixler can't tell if you tried this, but with my zen77 I did a sync with replace & interview. That helped quite a bit but ymmv.
January 10, 20233 yr Author @sjenkinsThanks for the suggestion. I just gave it a try but it didn't add the missing input devices to the ZEN17. No change on the ZEN16 either. However my ZEN71 switches are all working great. Thanks
January 11, 20233 yr Zen31 rgbw just needed the sync replace & interview ZSE44 temp humidity sensor required a removal from the network and reinstall. Bit of a hassle to redo programs. so far the powered units are working better than the battery units. next is the moisture sensors which I have a weird mix of Insteon, YoLink, and zwave zooz and zwave smart things. more to come.
February 1, 20233 yr Is there any update on the Scene nodes of the Zooz Zen 34 ? Has anyone been able to make it work in 5.5.4 on eisy with ZMatter ?
February 15, 20233 yr My 2 Zooz ZEN 34 initially migrated well from Zooz/Polisy to eisy/ZMatter, but the related programs stopped working after update 5.5.6 . One of the two programs was easily resolved with IF Basic Control is ON (or OFF) but the second ZEN 34 just did not register clicks in eisy. The issue appeared to be that I was not able to "write" updates to the device, even though I set it to stay awake. Finally after numerous tries the updating worked and then the ZEN 34 responded. Weirdly one of the two has Scene nodes but not the other. I have noticed that with these devices the Synchronize Update with Interview can creates problems with nodes disappearing, so I won't try that again and anyway the programs do what I want, so no need for the Scene nodes. But weird that only one of the two has Scene nodes.
