I just bought a used dimmer model 2477DR. It seems like any other of my many 2477D dimmer switches, but I have the hardest time adding it to my ISY. I keep getting the "cannot determine insteon engine" error. The circuit where it is connected to is electrically 'clean' enough for all other Insteon devices to get adopted/working. However, I also tried different circuits in the house to no avail.
What confuses me a bit is that the label says 2477DR. I have never come across this "R" version and seemingly google neither.
Any thoughts/pointers?
Thank you. That's what I thought.
So, the big questions remains, how do I get this device to play nicely with my network?
Make sure your isy firmware and UI matches. Factory reset dimmer. If you're adding using the address, make sure the address matches. Sometimes the #8 is mistaken for a B or D.
  • Like 2
you were spot on with the #8..... it is actually the letter B......duh!
Thank you!
Glad you found the issue.
You are not alone. I believe 0 and D are another one sometimes read incorrectly.
Could be worse. The older ones had a paper glued on label. That sometime fell of and got lost.  😁
  • Like 1
5 hours ago, Brian H said:
... The older ones had a paper glued on label. That sometime fell of and got lost.  😁
For future reference, is there a way to read out the device's address?
I use Magnifier on an iPhone if I'm in doubt... magnified you can tell the D vs 0 and the B vs 8.
Thanks. yep, taking a picture and zooming in is very helpful.
I was wondering however, if there is a way to read out the address if its label got lost.
Posted (edited)
@waffles If you <Start Linking> from the IoX top menu <Link Management> and then press the pull out tab button on the 2477 once, the IoX should list the new device along with it's address.
Edited by kzboray
  • Like 1
  • Thanks 1
2 minutes ago, kzboray said:
@waffles If you put the 2477 into link mode (press the pull out tab on the 2477 one time) and then in IoX start linking from the top menu <Link Management> it should be discovered and the address will be listed.
Got it, thanks! Thus far I have been using the 'light bulb' icon to add new devices. This seems to require the address to start the discovery.
I'm young enough I can still spot the difference unmagnified, but I have made the mistake a couple of times.  I just take a closer look and voila!
      37.6k
      376.2k
