Polisy ISY (IoX) Networking Web Server availability
Does the 994i ISY web server functionality still work with IoX?
I'm looking to capture some IoX node data to a file, but I couldn't quite figure out the process from the WiKi article. I customized a Notification with the Subject, @webpage:myDir/status.htm and some node data in the body of the notification. How do I activate or send that notification from an IoX program without sending an email?
Solved by vbPhil
2 hours ago, MrBill said:
I read this page in the wiki, which is what I think you're trying to do, but I don't understand it either.
Yes, that's what I read under the Dynamic/Custom Page Creation section. The only thing missing is actually how to call the customization from an ISY program without sending an email but creating a file at /user/web.
I see that page at http://IP.OF.THE.ISY:8080/WEB/udajax.htm so I guess "web" is still a thing.
14 hours ago, Ross said:
I just created this topic.  Perhaps if fits what you're looking for.
Thanks Ross that's what I was looking for. The technique shown from @Bumbershootis referencing the same WiKi article I've read but it doesn't completely explain everything. @MrBillwas showing me how he does a Google Sheet from Home Assistant using IoX data. I've started to pursue that as well.
I had put in a Support ticket for this. Chris just answered and said:
Quote
This will be fixed in tomorrows build.
The ticket was for:  Web Server Module - Dynamic/Custom Page Creation
