Zooz Zen34 worked on ISY994i but won't on Polisy IoX with Zwave/Zmatter board
Just migrated from ISY994i ZW+ IR PRO to Polisy IoX with Zwave/Zmatter board yesterday.  Everything is working fine except for one device.  I have 6 or so Zwave devices that I had to manually install and was able to get all of them to work except for the Zooz Zen34.  I am able to get it installed without a problem, but it won't control any devices.  It has three options on the switch, Wall Controller, Wake Up, and Basic Control.  The basic control, which I assume I would use to control other devices through scenes or programs doesn't have an option to turn it on or off via the ISY.  It only has Query.  I am able to install it in a scene with the Basic Control as the controller and my light as a responder, but it won't work.  Also, if I create a program with IF as the Basic Control on and then the light, still doesn't work when I press the Zen34 switch.
I have deleted all of the Zwave devices and reset the Z-wave dongle on the Polisy and reinstalled all devices once already.
Any thoughts?
Nothing specific for you but I have a couple ZooZ remote sensors that aren't working correctly, and UDI is aware and suggesting that it should be fixed in a future IoX update. I'm patiently waiting.
This is the only Zooz Zwave device I have, so it may not be compatible yet.  Thanks for the info.
I have posted on exactly the same issue. I am happy to note that this will be addressed in a future release.
