Serial PLM Kit and 2413S
What is the correct connection for the Serial PLM Kit with a 2413S  into Polisy Pro?
Eth > Serial adapter > serial to USB > usb port on Polisy
or
Eth > Serial adapter > serial port on Polisy
I think either will work on polisy. I'm using it with serial port directly but no reason USB shouldn't work. I think eisy only has usb though so that's the only way.
For the 2412S or 2413S. The PLM serial connector is a network style RJ45 with serial signals on it. As linked to in the previous reply.
There was a cable with the needed RJ45 to DB9S inside the boxes shipping material. Material not marked so many missed it or tossed it with the empty box.
There are some custom cables construction posts here also.
I ordered the Serial PLM Kit from UI.  So I've got it all setup now thanks to the advice above.  I'm using the serial port!
