SolarEdge APIs
  • 4 weeks later...
  • 3 weeks later...
 solaredge node server v1.1 is now in the non-production store for your testing.
v1.1 adds API rate limiting due to Solaredge 300 API call per day limits. If you set short poll to 60 (sec), for example, the "since last update" field will update every 60 sec to more accurately show you how stale the measurements are but still not exceed the Solaredge daily limits. This is especially helpful if you are logging measurements to a file so you can later see if any measurements are stale.
To set an API rate_limit other than the 5min default, enter a new "rate_limit" parameter (in minutes) in the custom parameters and save changes.
If you exceed the daily API limit or the solaredge server is overloaded you may see "since last update" exceed the rate limit.
Check it out and let me know if you have any issues.
