I cannot trigger programs from any Insteon switches when I push their local button, on or off.  I am using an IoX v5.5.4 with an Insteon 2413S PLM.
When I monitor the event viewer on level 3 I don't see any communications when I push the local switch buttons but I do see communications when I use the device menu.
My programs are set to activate on Control state on or off and they were working fine until I migrated everything to EISY.
I have tried a spare PLM, factory reset and restored, but same issue.  Tried factory reset and restored switches, but same issue.
Any suggestions for a fix would be greatly appreciated.
Thanks.
Thanks.
since you factory reset your plm file>restore plm>file>restore devices. Make sure your firmware and UI matches
