Show last motion time
Is there a way in UD Mobile app to show the last time a motion sensor detected motion or device was used?  Either a timestamp or relative time reference?
I had an alarm system at my previous house that would allow me to see when the last time a device or motion sensor was triggered and that was very helpful to view when I was away from home. It was a nice simple dashboard to easily see in a glance.
I use variables to track when a motion sensor is activated and or turns off...  These are not complete, but should point you in the right direction. Also the log file will track device operations as well.
If  YourMotionDevice is on
Variable = Minutes since start of day
_____________________________________________________
AllMotionSetCalcTime - [ID 0039][Parent 0032]
        $iAllMotionOffCurrentTime  = [Minutes since start of day]
Sets iAllMotionOffCalcTime to minutes since start of day.
Used to determine how long since motion detectors have been All Off
__________________________________________________________________----
MotionOn - [ID 0035][Parent 0032]
        'LivingRoomMotion.1 Motion' is switched On
     Or 'GarageMotion Motion Sensor' Status is On
        $sMotionOn  = 1
        $sMotionOff  = 0
        $iAllMTime  = 0
        $iVacant  = 0
 Warning:  Unrecognized Condition (program may not run)
<control OP="IS" NODE="ZW009_155" ID="DOF"/>
Not directly, but possible with a program as a favorite.   Programs show last run time, so if the sensor is used as a trigger, then the program last run time will be the last time the sensor was triggered.   In UD Mobile create a favorite with the program and change the display status to Last Run Time.  Initial Program status is disabled by default, so this must be enabled in system settings (Settings-Tab > System > System-Name > Program and Variable Settings.
