Month Total Missing Feb 1st
Today the monthly total is missing Feb 1st total, it is only showing today's use so far, Feb 2nd.  VUE itself has the correct total.
That is strange because the node server does not match what I get from the device which I believe is the cloud right?
https://web.emporiaenergy.com/#/home  is where I go to see the data.  Thank you for your reply, maybe it will fix itself tomorrow.
Yeah, I agree that it is strange.  They should match.  Possibly it's a bug in the library that's being used to do the actual queries.  It is a reverse engineered library as the Emporia cloud API is not publicly available.
Just for information my monthly reading matches the app. @btreindersif it does not look right I would try a Reinstall from the node server store.
It really had just stopped updating altogether.  The node server was still running but I went ahead and restarted it anyway and that fixed it. Thank you.  If you'd like the logs let me know.
