Updated from 4.7.5 to 5.3.0 and now Program Issues
I recently updated my firmware from 4.7.5 to 5.3.0 and now all my programs are yellow and showing out of memory.  I tried to delete and make new ones but the out of memory still shows.  I'm not sure what to try next.  I wanted to try to upgrade to 5.3.4 but I downloaded the firmware and when I tried to manual install it I don't know what file to use (I'm on a Mac Computer). What should I try?
Solved by tazman
It sounds like you need to clear your Java temporary files including Installed Applications. If you look in the AC under Help menu then About the firmware and UI must match.
My firmware is 5.3.0 but my UI is 4.5.4.  How do I upgrade my UI
You have to clear your Java cache then download the start.jnlp which is linked in the thread for upgrading your firmware.
So when I do what you said and I open the Console (Lan) they don't match. but if I open the Console (cloud) it matches and I tested a program and it seems to work
If you clear your Java cache including Installed Applications as shown below then download https://isy.universal-devices.com/start.jnlp that should sort it all out for you. This is all covered in the thread that has the firmware and instructions that I think you should take the time to reread so you can get everything updated with the proper firmware you need.
image.png.9e74bad4cbe5beb8e3518a3621449c
Thank you!  I was doing that but I kept on selecting to LAN Console.  Once I selected the Cloud Console or the dashboard thats when the Firmware and UI matched and able to run my programs
Your welcome. If everything is cleared properly it should work through the LAN console also.
