ISY Portal Logs showing Passwords?
Is that suppose to be logging passwords inside the <id></id> tags? I can't imagine why that would be a good idea...
TRI0N
Solved by bmercier
59 minutes ago, bmercier said:
What are you referring to?
Go into your ISY Portal > Select tools... > Logs > Error log. Passwords are shown in here...  inside <id></id> markup tags.
Thu 2023/01/12 10:38:25 PM System -170001 <s:Envelope><s:Body><u:SetUserCredentials xmlns:u="urn:udi-com:service:X_IoX_Service:1"><val>0</val><name>admin</name><id>MY PASSOWRD IS SHOWN HERE</id></u:SetUserCredentials></s:Body></s:Envelope>
Just search for your password (CTRL-F).. LoL - Mine shows up 55 times in that log...
TRI0N
Edited by TRI0N
TRI0N
This is your ISY error log. Portal does not capture anything from this data.
But I agree it probably should not appear in the ISY error log in the first place.
