Tried migration to eISY/ZMatter and reverted back to Polisy/Zooz - ZWave Scene Issue
JTsao
This past weekend I performed a migration from Polisy/Zooz to eISY/ZMatter but ended up going back mainly due problems with Node servers not working - I have some Zooz Zen71 and Zen77 switches in one area of the house and had 3 switches grouped together in a scene - I think that ZMatter does some Z-Wave scene setup because now, after going back, I have one switch still controlling 3 lights and I have since redefined the scenes - Is there any way with the Zooz ZST10 dongle to manually erase the scene setup or adjust it?
Sounds like you used basic association in ZMatter for these, which allows switches to control others without a controller.
If you exclude/include it should reset them.
But I am wondering how you got them back on the Zooz stick without doing that already? Maybe need to do a full reset of the switches... Zooz should provide instructions how to do.
Or you can try loading up the silicon labs software with a zooz stick and remove the basic associations that way from the switches. I discussed this before, so go search in the older ZWave forum.
Are you suggesting that it should not have been possible to migrate to ZMatter and then just switch back to the Zooz controller?  That's what I did and all my Z-Wave equipment works - I was thinking that this could be a problem as well...
I do have the Silicon Labs software and have updated Zooz ZST10 firmware before and performed backups but I will need to re-read the forums to learn exactly how associations work
Does this indicate that the "LR Lts ZW034" device is controlled by "LR2 Lts ZW035"?
      37.5k
      375.5k
