UDMobile strange behavior
UD Mobile has worked fine for me since I started using it about 4 months ago. Now it is working for 20-25 seconds then looses status and won’t trigger any commands for 20-25 seconds and keeps repeating this behavior. It still shows it is connected and wifi is solid but it keeps looping the 20-25 second on/off behavior.
I just installed Iox 5.5.5 not sure if that has anything to do with it.
I am 100% Zwave on Polisy 5.5.5
Edited by trevorst
Solved by trevorst
Hi @trevorst,
If the only thing that change is the firmware upgrade, it is the likely culprit.  Please open a ticket under the UD Mobile category.  If you have a portal account please include your UUID and we may be able to run diagnostic.
Solved loaded 5.5.6 of iox and power cycled after that cleared up the problem.
