Posted November 16, 200717 yr I use this program to run a fountain pump at different times of the day with separate run times. If From 7:00:00AM For 20 minutes Or From 11:00:00AM For 20 minutes Or From 3:00:00PM For 20 minutes Or From 6:40:00PM For 15 minutes Then Set 'Fountain Pump' On Else Set 'Fountain Pump' Off
December 20, 200717 yr I did a simular program for my Christmas tree. If From 6:00:00AM For 2 hours Or From Sunset To 11:30:00PM (same day) Then Set 'Christmas Tree' On Else Set 'Christmas Tree' Off
December 21, 200717 yr Unless you are using LED's, how are you plugging in the tree? Lots of wattage on an appliancelic otherwise! aLf
December 21, 200717 yr I have a 650+ light pre-lit tree (bah humbug) with incandescent mini lights. My Kill-A-Watt says it's using 255 watts. I'm controlling it with an Icon On/Off adapter rated at 480 watts.
