Feature Enhancement: Add temp to motion sensor values passed to ISY.
@Panda88
Hi Not sure if you prefer info communicated via this forum or GitHub so I have posted this in both places.
Can we get the temp value sent to the isy for motion detectors.
Solved by Panda88
After a quick look, I only see the temperature being sent when you query the device (getState).  Not on alerts or updates.  It also shows -1 in the log I found.
I am not 100% sure, but my experience with battery operated devices a getState to the device gets a cached value (from last update from cloud) - not current.  It simply burns too much power constantly querying it.
I can take a look at providing access to this, but be aware of the above  - It is possible the temperature is updated upon alerts (and can be retrieved afterwards), but we cannot force an update besides the normal report cycle (hours) when no motion occurs
I need to compare indor and outdoorl Motion sensors to be 100% sure of how it operates (it is not documented in the API documentation), but my guess is they would report the same.
Git or here is fine as long as I am mentioned (so I get a message)
While you're looking into this could you also check leak sensors? In the YoLink app the leak sensor details show temperatures, which could be useful.
Sure - but I believe the issues will be similar :-)
Added sensor  temperature reporting for 0.8.50.  Let me know if it works.
Good Morning
Just upgraded and the temp is there now.
Thank You
