March 21, 201016 yr I had to reformat my hard drive today. So when I went to set up my ISY 99 I and Power line Modem Module. I go into the Admin Console All devices current state is blank I can not control anything from the computer All my devices are present in the network My remotelinc works fine. The RX light is always on for the universal Device How can I get it back so I can turn things off and on from the computer? Thanks for the help Dodger
March 22, 201016 yr Hi Dodger, I am so very sorry to hear this. If the RX is lit all the time, then you are surely having a PLM issue. What you want to do is: 1. Unplug your PLM from the outlet, wait for a minute, and then plug it back in. If this does not solve the issue, then 2. Try using a different cable between the PLM and ISY, if this does not solve the issue, then 3. I strongly recommend getting a replacement PLM With kind regards, Michel I had to reformat my hard drive today. So when I went to set up my ISY 99 I and Power line Modem Module. I go into the Admin Console All devices current state is blank I can not control anything from the computer All my devices are present in the network My remotelinc works fine. The RX light is always on for the universal Device How can I get it back so I can turn things off and on from the computer? Thanks for the help Dodger
