Delete node servers
Go to solution Solved by bpwwer,
I migrated from the ISY994 to Eisy and i'm working on the fall-out of this migration. One issues is wrt PG3 -  The nodes in PG3 are listed as "unmanaged" - I was able to resolve some of this by re-installing them from the new Node Store - but others I simply want to delete - but I'm unable to find a way to do this from the GUI. What's the process for this?
unmanaged, means that they are not being managed by PG3 but by something else. That's why you can't delete them.
In your case, I suspect they are being managed by a previous installation of PG3?  or PG2?
You can delete them from the Admin Console.  Go to Node Servers -> Configure -> slot number for the node server slot you want to delete and click on the "Delete" button.  After a few minutes they should disappear from the PG3 dashboard.
      37.6k
      376.2k
