IoX Release v5.5.9 (Polisy/eisy) - OUTDATED
* IoX = ISY on Anything.
Welcome to ZMatter Z-Wave+ Beta v5.5.9 !
Features
  • Initial support for Insteon I3 Devices (I3 4-Button keypad, I3 Dual outlet, I3 Dial, I3 Paddle)
  • Preparation for remote PG3
  • Preparation for move to PG3x (on Polisy)
  • The Admin Console now notifies you of the different stages of the upgrade process. i.e. reboot, do nothing, update available, upgrading
Bug Fixes
  • Z-Wave Network Heal (should improve response time for door locks)
  • Z-Wave Smoke Alarm not reporting events (also impacts CO/CO2/Water Valve)
  • System value in programs: first Day Of Year is 1 (was incorrectly 0)
  • Nodes not always saved to file system after synchronization
  • 'Event received for a different subscription' error dialog
  • Spurious Update Available messages
Getting Started
  • Make a backup of Polisy or eisy (Admin Console | File | Backup IoX )
  • Launch the Admin Console, go to the Configuration tab, click on Update Packages. Warning, this might take a while depending on how current your OS is
  • On eisy
    • If you are using INSTEON, make sure the PLM is connected
    • Restart the Admin Console and make sure you are on 5.5.9. You will be notified of what should be done next including a reboot
  • On Polisy
    • Once completed (4 beeps + 1), click on Admin Console | Polisy System | Reboot
    • Power up your Polisy note that initial boot might take a much longer time than normal because udx might want to install missing packages to assist with migration (in the future)
    • Once boot up is complete, Launch Admin Console
Migrating to ZMatter Z-Wave+
Here are the installation instructions for those of you with a ZMatter Z-Wave board (not USB dongle):
