frank Posted March 9, 2023 Posted March 9, 2023 Has anyone had success installing the Aeotec window/door sensor 7 Pro on your ISY 994iZ Pro? If so, could you assist me?Also, is there a better sensor than the above. I am presently using the Aeotec motion detector 7 and it works fine. Sent from my iPhone using Tapatalk
Techman Posted March 9, 2023 Posted March 9, 2023 @frank What are your ISY firmware and UI versions? Do you have the 300 or 500 series Z-wave board? What happens when you try to install the Sensor?
