Attempting To Migrate To Eisy
Disconnecting from and reconnecting to power solved my issue!
I'm attempting to Migrate to Eisy from ISY 994. The Eisy firmware is 5.5.9 and ISY firmware is 5.3.4. I attempted to restore the Eisy from a 994 backup and I get the message in the image below. What did I do incorrectly?
Thank you!
Edited by dbuss
Problem resolved
Same problem here migrating from Polisy to eisy.  ISY on eisy won't show up in finder, but sometimes if I manually add it I can see it, but then get the same error as you when I try to connect.  I don't want to reboot since I have no idea how to tell if the zwave migration has completed yet.
I replied to your other post. I thought (?) the log you ran was for Zwave. I suggested another one that I thought you would be able to see the upgrade process on.
Not sure if there is a difference, the one I posted was for a Polisy.
