Seemingly endless Linking
I started linking to add a dimmer but the dimmer was already in the isy I just had to enable it but now it is endlessly Linking.  Takes about 5 minutes to get to 100% then starts all over again.  Has been doing this for about 20 min now.  I tried clicking the x in the top right corner but that did nothing.  Any idea?
Solved by DennisC
Which UD device? If Polisy or eisy, use the multi function button to do a shutdown and then restart the unit manually.
Check the user guide wiki to determine the correct number of button presses for your unit.
