Are these issues caused by the node server?
I have 5 Kasa lights and every once in a while they lose connection with the app and Polisy and even the manual button wont turn them on.  The only way I can get them to work is by unplugging them and plugging them back in.  the only one that has not had this issue is the one closest to the wifi router.  Not sure why even the button wont turn them on.
If they're losing connection to the app then it's a product issue/network issue. I'd contact the mfg.
Have you tried moving the problem devices to the area where you don't have an issue? If they all work fine there then it may be something environmental
I was assuming wifi signal but weird why even the button wont turn them on at those times.  I will try to contact them.  Thanks
That would be hardware
