No configuration options in node server
I just installed a gen 4 August wifi lock and am trying to get the August nodeserver to work with it.  ver 3.1.1, Polisy 5.52, Polyglot 3.1.10.  I get the controller in PG3 (1 node)  but there is no place to input the parameters indicated in the instructions (email, password, install_id, tokenFilePath).
I attached a log file.
In the admin console in IoX I do get the controller and an August Lock node to add but since I don't have node address I am not able to add it.
Any help appreciated.
August_3-21-2023_122222_PM.zip
Solved by DennisC
Setting the parameters by adding Custom Parameters eventually worked.  I had to reboot policy a number of times, watch for emails, install and uninstall the node server several times but eventually it worked.  Thanks @DennisC and @dpwwer.
