Version 2.0.5 Won't Install
I noticed there was a new version so I restarted the node server and now it says not running and will not restart or start and still shows message for new version.  I restarted PG3 and still not running with new version message.  Any ideas?
Can you PM logs to me, please. I will only be able to deal with it next week though.
Maybe try remove and clean install if you haven’t already.
Clean install fixed it and now I am having a very similar issue with another node server.  It won't install but does at least run.  I am reluctant to reinstall it since it is very involved to install and in a lot of programs if I screw up.  So must be a PG3 issue and not just single node server.  Thank you!
Edited by btreinders
Yes, but now it does not (yet) discover my Google Home and Chromecast devices. (I did change false to true in the ns).
Also having issues with v 2.0.5. Just loaded after a reboot today.  It is not communicating with eisy and I can not delete it for a fresh install. I keep getting the message: "Failed to remove node server AVRemote from slot (13). Can not read properties of null (reading 'filename')".
No log is produced. Deleted all nodes but still won't delete from PG3. Thanks for any assistance.
2.05 still not getting the 3  Chromecast devices, after setting false to true and rediscover in AVRemote Controller in Administrative Console.
Edited by asbril
This was the issue with PG3x, specifically. It is fixed now with latest update.
I cannot comment on other node server but I recommend it because I've changed how data is saved in this version. Better to start clean.
