YoLink NS installation issues
I am running V0.8.50 and am seeing some installation issues with trying to upgrade to the latest version (0.8.88) of the YoLink node server.  If I restart the node server, it briefly reflects that the version was updated to V0.8.88, then a few seconds later it displays V0.8.50 again.
I think this issue has been there for a little while, but I was able to previously get around this by deleting the old Node Server and doing a clean install of the latest version, but that no longer seems to work.  If I try to delete the existing Node Server I get an error "Failed to remove Node Server YoLink from slot 60: Cannot read properties of null (reading 'filename')".
Any suggestion on how to install the latest version?
Edited by dwengrovitz
updated formating of text slightly
Solved by Panda88
Did you try to upgrade from the AC - I heard there was a bug the prevented deletion of files in a prior version
I tried upgrading via PG3x (by either restarting the node server, or attempting to delete and reinstall).  I wasn't aware there was a way to upgrade node serves from within the AC.
Ahh, got it.  I updated pg3x to 3.1.24 and the issue with not being able to update the node server via a restart was still there, but I was able to successfully delete and reinstall the node server to get the latest version.  Thanks very much for the assistance!
