Posted November 17, 200717 yr I'm probably missing something here, but, for the limited testing I've done, I only get two types of Email subjects/bodies: X10 Alert! Sched Alert! For the X10 Alert, the email body includes: 11/17/2007 15:18:47: At My Lighting:X10 has changed to A.1.3. which is useful, although not specific to which program sent the notification. But, the Sched Alert email body is: 11/17/2007 15:38:47: At My Lighting:Sched has changed to Met. The Progam that called Send Notification was named "Notify A Visitor Is Entering Driveway" and its program is: If Program 'isVehicleIncoming-Program' is True Then Send Notification to All Run program 'Notify A Visitor Is Entering Driveway' (Else Path) Else - No Actions - (To add one, press 'Action') How can I get the calling program name included in the body of the email so that I will know which of the many programs that could have called Send Notification actually sent that specific email? Thanks, Frank.
November 18, 200717 yr Hi FrankF, Unfortunately, you cannot at the moment. Our next release (2.6) will include email templates. With kind regards, Michel I'm probably missing something here, but, for the limited testing I've done, I only get two types of Email subjects/bodies: X10 Alert! Sched Alert! For the X10 Alert, the email body includes: 11/17/2007 15:18:47: At My Lighting:X10 has changed to A.1.3. which is useful, although not specific to which program sent the notification. But, the Sched Alert email body is: 11/17/2007 15:38:47: At My Lighting:Sched has changed to Met. The Progam that called Send Notification was named "Notify A Visitor Is Entering Driveway" and its program is: If Program 'isVehicleIncoming-Program' is True Then Send Notification to All Run program 'Notify A Visitor Is Entering Driveway' (Else Path) Else - No Actions - (To add one, press 'Action') How can I get the calling program name included in the body of the email so that I will know which of the many programs that could have called Send Notification actually sent that specific email? Thanks, Frank.
November 18, 200717 yr Author Thanks. If you find a simple/quick (I know ...) way to just send the name of the program calling "Send Notification to All" in an upcoming beta, that would be sufficient for me. At least for now. Maybe just pass the known calling program name as a parameter to "Send Notification". Thanks, Frank.
November 18, 200717 yr Frank, That sounds good. No guarantees but let us see what we can do. With kind regards, Michel Thanks. If you find a simple/quick (I know ...) way to just send the name of the program calling "Send Notification to All" in an upcoming beta, that would be sufficient for me. At least for now. Maybe just pass the known calling program name as a parameter to "Send Notification". Thanks, Frank.
