Migrated from ISY to Eisy. How do I make eisy program push F# button?
Just bought the Elk node today and I am setting up.  So far so good.
One thing I cant figure out is how do I have an eisy program push an Elk Keypad F# button?  In ISY I had a program that if leak detector had a leak, it would programmatically push the F5 button on the ELK keypad to cause the Elk to voice announce a water alarm.  I also use it to voice announce a mailbox open alarm by pushing another Keypad F key.
Please let me know how I can do this.  Thanks!
Solved by DennisC
There is an open issue regarding this. Currently, you can only trigger a program via function keys based on Status of Last Key.
You can read more about it here:
For now, a work around is to set an Elk output when a F key is pressed and then run the program when the output turns on/off. As described here:
However, in your case, you are looking to press a F key to have Elk speak, but I would ask why do it that way?
Why not just have the Elk node server tell Elk to speak the words?
Thanks @DennisC
For the mailbox voice alert, that is what I do just speak the words as you show.
For the water alarm, I want for it to actually activate the siren alarm in the house as well.  I programed a key on Elk keypad to set off water alarm that worked great with ISY.   I can do the speak words option for it as well.
Looks like it is in the enhancement list.  So I will use the words option for both alerts.
12 minutes ago, TheA2Z said:
Thanks @DennisC
You can still either chirp the siren alarm x times or have the keypad beep. All you need to do is go to ElkRP2 and enable an output, you can call it Siren or whatever you want.
Next, create a rule that when the named output (ex: Siren) turns on, then either chirp the siren x times, or beep keypad, or both.
Back in ISY - Polisy - eisy, add to the Then portion of your program to turn the output you just created (ex: Siren) on for x time, or even cycle it on/off several times to get the desired effect.
  • 3 weeks later...
