ISY to EISY - Home assistant Migration - change port info?
Hi,
I had an ISY setup with home assistant, buttons set as I like them.  I have the Eisy, migrated from the ISY to EISY properly (I think).
My old ISY had a non-https url:
http://192.168.1.80
My new EISY (seems to have no web interface but thats a different issue:
https://192.168.1.80:8443
Can I either change the EISY URL from the HTTPS://IP:8443 to http://ip:80
or
How do I edit home assistant so it knows to look for the ISY settings at the new EISY URL?
Rich
  • 4 weeks later...
Thank you - I did follow this and it worked great BUT:
If I reboot - everything is great / perfect works as expected.
If I upgrade Home Assistant, nothing works - its all greyed out.
Any idea why it works fine until i upgrade home assistant?
You have to be more specific what is all greyed out.
You are saying if you upgrade home assistant it stops working? Then what do you do in this case, revert to an older version of Home Assistant and continues to work?
I upgrade my home assistant constantly and no issues... they have upgrades each month at minimum and never had issue with the ISY integration.
Posted (edited)
Sorry - that was not specific - I edited the config to go from ISY994Pro to Eisy within home assistant.
My 'Rich Lights" page works just fine before & after the edit.  On the page, I can toggle lights on & off - works as expected.
When I upgrade Home assistant, the upgrade works fine, all other integrations work as expected but
the "Rich Lights" page which was working correctly with the blue tabs to turn lights on & off are grayed out with no option to move.
The projector screen grab is a 'example' of the grayed out.  I think the error is an integration failure after the Home Assistant upgrade?
EDIT:  I am wondering if my editing of the files to migrate from ISY to EISY is the issue? I used notepad ++ and it works on the current HA Version I am on 2023.4.6
Eisy version 5.5.9
Edited by RichTJ99
more info
Hrmm - i think i followed step 2 and am now wondering if I didnt stop home assistant when i did the find & replace.
Assuming I didnt do that (because reading it now i am not sure how to stop home assistant to do that) - I did get it working/pointing to the new Eisy - it does survive a reboot/shutdown of home assistant - but breaks during an upgrade.
Any chance i can fix it in this home assistant where it will work after an upgrade?
My confusion is that everything works fine now just breaks after the upgrade.
So I think I have it squared away.
I did a find/replace changing the URL from http://192.168.1.2 with my ISY
to
https://192.168.1.2:8443
this worked until the upgrade
Today I upgraded again, it failed again but i swapped the URL to
http://192.168.1.2:8080
This worked after the upgrade BUT I will have to see if it sticks after the NEXT home assistant upgrade.
Posted (edited)
You may be missing doing a replace on one of the files. Make sure you do all of the ones listed in that post and double check the MAC address replacement too, and then reboot HA right away. It should be surviving an upgrade if it survives a reboot.
Worst case, do option 1 and remove/re-add the integration.
Edited by shbatm
      37.3k
      373.6k
