Changed Area Names in ELK
1 hour ago, Barefooter said:
I changed the Area names in the Elk but I cannot get it to change in the eisy.
From the directions:
"If you change a Elk object name it will not be automatically reflected on the ISY (currently). You will have to delete the node in the Polyglot UI Node's page for the node server, then restart the node server."
You will also need to restart the admin console.
