Issues upgrading to eisy
I had the Kasa node server running perfectly on polisy (PG3).  Since upgrading:
  • New nodes are not appearing within Kasa
  • Some old nodes are appearing offline and/or have incomplete information and/or are showing an old IP address
  • I have removed and reinstalled the nodeserver, at which point only the controller is populated in eisy, not child nodes, and in PG3 there are no child nodes populated either
  • after restoring a backup of PG3 and eisy to the state they were at when it was migrated, back to the original - some nodes are offline, some have incomplete info, etc.
  • The log shows various errors, such as:
2023-05-17 13:39:55,488 Command    udi_interface.interface ERROR    interface:_handleInput: _parseInput: failed 9c53229e0811.runCmd(DON) Communication error on system:set_relay_state
Traceback (most recent call last):
  File "/usr/local/lib/python3.9/asyncio/streams.py", line 52, in open_connection
    transport, _ = await loop.create_connection(
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 1050, in create_connection
    sock = await self._connect_sock(
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 961, in _connect_sock
    await self.sock_connect(sock, address)
  File "/usr/local/lib/python3.9/asyncio/selector_events.py", line 500, in sock_connect
    return await fut
asyncio.exceptions.CancelledError
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.9/asyncio/tasks.py", line 490, in wait_for
    return fut.result()
The above exception was the direct cause of the following exception:
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/protocol.py", line 131, in _query
    await self._connect(timeout)
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/protocol.py", line 81, in _connect
    self.reader, self.writer = await asyncio.wait_for(task, timeout=timeout)
  File "/usr/local/lib/python3.9/asyncio/tasks.py", line 492, in wait_for
    raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/smartdevice.py", line 251, in _query_helper
    response = await self.protocol.query(request=request)
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/protocol.py", line 73, in query
    return await self._query(request, retry_count, timeout)
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/protocol.py", line 148, in _query
    raise SmartDeviceException(
kasa.exceptions.SmartDeviceException: Unable to connect to the device: 10.214.126.99:
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/udi_interface/interface.py", line 889, in _handleInput
    self.nodes_internal[item['address']].runCmd(item)
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/udi_interface/node.py", line 166, in runCmd
    fun(self, command)
  File "/var/polyglot/pg3/ns/0021b9026524_12/nodes/SmartPlugNode.py", line 40, in cmd_set_on
    super().cmd_set_on(command)
  File "/var/polyglot/pg3/ns/0021b9026524_12/nodes/SmartDeviceNode.py", line 334, in cmd_set_on
    self.set_on()
  File "/var/polyglot/pg3/ns/0021b9026524_12/nodes/SmartDeviceNode.py", line 164, in set_on
    res = fut.result()
  File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 446, in result
    return self.__get_result()
  File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 391, in __get_result
    raise self._exception
  File "/var/polyglot/pg3/ns/0021b9026524_12/nodes/SmartDeviceNode.py", line 169, in set_on_a
    await self.dev.turn_on()
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/smartplug.py", line 58, in turn_on
    return await self._query_helper("system", "set_relay_state", {"state": 1})
  File "/var/polyglot/pg3/ns/0021b9026524_12/.local/lib/python3.9/site-packages/kasa/smartdevice.py", line 253, in _query_helper
    raise SmartDeviceException(f"Communication error on {target}:{cmd}") from ex
kasa.exceptions.SmartDeviceException: Communication error on system:set_relay_state
After restarting, the following occurs:
2023-05-17 13:39:13,465 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartDimmer', 'name': 'Driveway Overhead', 'host': '10.214.126.180', 'mac': '34:60:F9:F5:7A:D3', 'model': 'KP405(US)', 'address': '3460f9f57ad3', 'emeter': False, 'id': ''}
2023-05-17 13:39:13,466 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'greenhouse', 'host': '10.214.126.176', 'mac': '10:27:F5:9C:5D:0D', 'model': 'KP115(US)', 'address': '1027f59c5d0d', 'id': ''}
2023-05-17 13:39:13,467 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'Polisy2', 'host': '10.214.126.184', 'mac': 'B4:B0:24:E0:E2:82', 'model': 'HS103(US)', 'address': 'b4b024e0e282', 'id': ''}
2023-05-17 13:39:13,468 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'Butler Pantry', 'host': '10.214.126.178', 'mac': '1C:61:B4:B0:B3:9B', 'model': 'HS200(US)', 'address': '1c61b4b0b39b', 'id': ''}
2023-05-17 13:39:13,469 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'Pi', 'host': '10.214.126.181', 'mac': 'B4:B0:24:E0:F0:89', 'model': 'HS103(US)', 'address': 'b4b024e0f089', 'id': ''}
2023-05-17 13:39:13,469 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'greenhouse fan', 'host': '10.214.126.99', 'mac': '9C:53:22:9E:08:11', 'model': 'HS103(US)', 'address': '9c53229e0811', 'id': 'SmartPlug_NN'}
2023-05-17 13:39:29,679 Thread-62  udi_interface      WARNING  SmartDeviceNode:handler_poll: greenhouse fan: Node not ready to poll, must be disconnected or slow to respond?
2023-05-17 13:39:35,455 Thread-8   udi_interface      ERROR    SmartDeviceNode:connect_a: greenhouse fan: Unable to update device 10.214.126.99 will try again later: res=False
These are all devices online in the Kasa app.  10.214.126.99 is not the correct IP address for greenhouse fan, it should be 189, but it's not updating.  Hasn't been 99 in several weeks.
After restarting, all nodes disappear, and the following:
2023-05-17 13:49:03,930 MainThread udi_interface      INFO     __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.59 Starting...
2023-05-17 13:49:03,994 MainThread udi_interface.interface INFO     interface:__init__: Initialization received from Polyglot V3 3.1.26  [ISY: 5.6.0, Slot: 12]
2023-05-17 13:49:03,995 MainThread udi_interface.interface INFO     interface:__init__: Connect: Network Interface: {'addr': '172.26.18.3', 'netmask': '255.255.255.0', 'broadcast': '172.26.18.255'}
2023-05-17 13:49:03,995 Interface  udi_interface.interface INFO     interface:_startMqtt: Connecting to MQTT... localhost:8883
2023-05-17 13:49:03,996 MainThread udi_interface.interface WARNING  interface:start: No node server version specified. Using deprecated server.json version
2023-05-17 13:49:03,996 MainThread udi_interface.interface WARNING  interface:db_getNodeDrivers: tplkasactl not found in database.
2023-05-17 13:49:03,996 MainThread udi_interface.interface WARNING  interface:send: MQTT Send waiting on connection :: {'config': {'version': '3.0.21', 'requestId': False}}
2023-05-17 13:49:03,998 Interface  udi_interface.interface INFO     interface:_startMqtt: Using SSL certs: 0021b9026524_12.cert 0021b9026524_12.key
2023-05-17 13:49:04,005 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Connected with result code 0 (Success)
2023-05-17 13:49:04,005 MQTT       udi_interface.interface INFO     interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:24_12 -  MID: 2 Result: 0
2023-05-17 13:49:04,048 MQTT       udi_interface.interface INFO     interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,)
2023-05-17 13:49:07,043 MainThread udi_interface.interface INFO     interface:addNode: Adding node Kasa Controller(tplkasactl) [None]
2023-05-17 13:49:07,044 MainThread udi_interface.interface INFO     interface:setController: Using node "tplkasactl", driver "ST" for connection status.
2023-05-17 13:49:17,360 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartDimmer', 'name': 'Driveway Overhead', 'host': '10.214.126.180', 'mac': '34:60:F9:F5:7A:D3', 'model': 'KP405(US)', 'address': '3460f9f57ad3', 'emeter': False, 'id': ''}
2023-05-17 13:49:17,361 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'greenhouse', 'host': '10.214.126.176', 'mac': '10:27:F5:9C:5D:0D', 'model': 'KP115(US)', 'address': '1027f59c5d0d', 'id': ''}
2023-05-17 13:49:17,362 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'Polisy2', 'host': '10.214.126.184', 'mac': 'B4:B0:24:E0:E2:82', 'model': 'HS103(US)', 'address': 'b4b024e0e282', 'id': ''}
2023-05-17 13:49:17,363 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'Butler Pantry', 'host': '10.214.126.178', 'mac': '1C:61:B4:B0:B3:9B', 'model': 'HS200(US)', 'address': '1c61b4b0b39b', 'id': ''}
2023-05-17 13:49:17,364 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'Pi', 'host': '10.214.126.181', 'mac': 'B4:B0:24:E0:F0:89', 'model': 'HS103(US)', 'address': 'b4b024e0f089', 'id': ''}
2023-05-17 13:49:17,364 Thread-8   udi_interface      WARNING  Controller:_discover: Adding previously known device that didn't respond to discover: {'type': 'SmartPlug', 'name': 'greenhouse fan', 'host': '10.214.126.99', 'mac': '9C:53:22:9E:08:11', 'model': 'HS103(US)', 'address': '9c53229e0811', 'id': 'SmartPlug_NN'}
2023-05-17 13:49:33,520 Thread-62  udi_interface      WARNING  SmartDeviceNode:handler_poll: greenhouse fan: Node not ready to poll, must be disconnected or slow to respond?
2023-05-17 13:49:39,421 Thread-8   udi_interface      ERROR    SmartDeviceNode:connect_a: greenhouse fan: Unable to update device 10.214.126.99 will try again later: res=False
2023-05-17 13:50:03,550 Thread-69  udi_interface      WARNING  SmartDeviceNode:handler_poll: greenhouse fan: Node is now ready to poll
All of the nodes other than greenhouse fan do respond even though they have disappeared in PG3 and it says they didn't respond to discover.  The fan which is still the wrong IP does not respond.  And no new nodes I've added to Kasa appear....
This is a lot I know, I can provide specific actions and associated logs if needed.  Thanks!
Edit: I restored everything from backups from the migration day, did another migrate on PG3x, unplugged and plugged in all the Kasa devices, and the existing ones seem to be working mostly now, but still not seeing anything I've added since the eisy migration.
Edited by skunkiechris
