Does "On" = 100%?
I have the following program to turn some lights off at night:
Time is 12:22:00AM
Wait 40 minutes (Random)
Set 'Rec Room Track' Off
I also have a program that turns the lights on to 90% just before sunset. If I go into that room, I manually flip the Insteon switch up, which brings the lights up to 100%.
There are times when I'm in that room well past the time when the program turns the lights off. I want to modify the above program to only turn the lights off if they are NOT at 100%. However, when I go to add that condition, there is no option for 100%, so here is how the statement looks now:
Time is 12:22:00AM
And Status 'Rec Room Track' is not On
So, does "On" equal 100%? It seems to me that this statement will be true no matter what the level is. Why isn't there an option for 100% in the drop-down list?
I see why this is confusing, because my experience is that status is ON is true for anything but OFF. I could be wrong, thourgh.
For what you are trying to accomplish might I suggest:
1) For your program that turns the light on before sunset (call it "TrackOn"):
       Time is Sunset  -  5 minutes
   And (
            Status  'Rec Room Track' is On
         Or Status  'Rec Room Track' is Off
       Set 'Basement / Playroom Track Lights' 90%
2) Then for the program that turns the light off
       Time is 12:22:00AM
   And Program'TrackOn' is True
In this scenario the lights will always be set to 90% at 5 minutes before Sunset and teh program TrackOn will be set to true. However, any subsequent status change, whether turning them to 100% from the switch or turning them off, will trigger the "TrackOn" program and set it to false (because the time is not 5 minutes before sunset). At 12:22, the second program will only turn the lights off if the "TrackOn" program is True, i.e. the lights were set to 90% at 5 minutes before sunrise and have not been changed since.
Yes, that it a reasonable understanding by a reasonable person. If I recall correctly, however, the ISY also has a condition "not off". So, you have the ability to have a condition of "on" = 100% and "not off" = 1% - 100%. Pick one that meets your needs.
Thanks everyone for the quick replies.
I'm going to test this tonight.
Well, operating under my standard "believe but verify" approach (as my wife puts it), I went through my programs in the ISY and it turns out that I don't ever use 'status is On'; only 'status is Off' and 'status is not Off'. So my understanding that status of On was anything other than status is Off was not only incorrect, it was unfounded.
I was wrong, you were right, and I am sorry (my wife would be so proud) ;)
I am sure that you were right, but just haven't come up with a good explanation for you wife. Remember, between the husband and wife, the husband is always right. Also remember, what is said in the forum stays in the forum.
