Two small issues with 3.5.1
1. Not a big deal but after updating my UD Mobile it deleted my API key for UD Mobile.  No big issue- Just added it again.  All other configs stuck.
2. In screen in picture, should we not be able to specify a single device.  I know it says group but for testing I want to test just to my device not my entire family.  This lets me ONLY select my family group.  I think it should be Group/Device
Edited by macjeff
Solved by Jimbo.Automates
I guess for #2 above you can create a group for each phone in the family.  That would accomplish the same thing.
1. No, it is a new parameter, the existing one on the ISY Portal Service node should still exist.
2. The preference is to use groups always so if you change the name of your phone it will still work, and when you get a new phone it can be put in the group and the old one removed.  I will be adding groups to the "devices" list in the ISY Portal Service node so you can chose to use either.
