Node server not working
Is anybody else having issues with the node server working? I'm getting this error
2023-06-12 20:08:49,313 Thread-6   udi_interface      ERROR    TeslaEVController:createNodes: Exception Controller start: 'display_name'
2023-06-12 20:08:49,313 Thread-6   udi_interface      INFO     TeslaEVController:createNodes: Did not obtain data from EV
I tried redoing the refresh token but it did not help and I'm wondering if there is an issue because Tesla changed something.
Solved by Panda88
Can you try to enable debug in the log
  1. Hopefully it can show more - I do not have access to a car to try so hopefully the log can shed some light on this
I did have the log on debug and I don't notice anything else but I can PM you the log later today to see if anything else looks wrong to your trained eye. Thanks for the quick reply!
Another user raised this issue - seems they have changes the naming of one of the keys - need to see if others have changes as well.
I will be travelling but will try to get a fix out soon
Can you try a new install - I am not able to update the node store, but if you install now is should pick the latest code.
There are changes in the structure from tesla so there may be other changes needed in the code, but I cannot test as I do not have a car
Awesome Panda88 you got it! The node created in the AC is now called EV1 instead of the car name which does not matter to me and everything looks good to me initially. Thank you for your quick response!
