State Variable - Doesn’t trigger from Favorite
I have a state variable that I use to indicate if home or away on vacation that I have various programs use. If I change the variable from the UD Mobile Home->IOX System->Variables menu it triggers the various programs on my ISY just fine. So I decided to put the variable as a favorite with type default.  When I change the state variable from the favorite screen/menu it doesn’t trigger programs in the ISY, only when I change it at Home->IOX System->Variables.  Weird. Is this a bug in UD Mobile favorites?
Edited by jwagner010
When clicking the Default favorite for a variable or when clicking on the home screen the same "Node Dashboard" is opened so I don't believe it would have nothing to do with Favorites.
My guess is the variable already changed so a Status change was not triggered.   Can you verify Variable status is enabled in UD Mobile> Settings Tab> Systems> System Name > Program an Variable Settings?
Yes it is enabled.  Works without fault from Home Screen just not from favorites.
