Set Elk alarm in UDmobile
Tried going into elk node in UD mobile for eisy.  Trying to set the alarm in stay or away mode in UD Mobile app.  Is it possible?
Solved by Jimbo.Automates
4 hours ago, Jimbo.Automates said:
Yes open your area node and set armed status. You can create a favorite to armed status to make it easier.
Sent from my Pixel 6 Pro using Tapatalk
Thanks @Jimbo.Automates.
The only Armed Status that will set my Elk with UDmobile or IoX is "Armed next Stay Mode" or "Armed next Away Mode".
Is that the only two that allow you to change the actual armed status of the Elk alarm from eisy IoX or UD Mobile?
12 hours ago, Jimbo.Automates said:
You aren't able to select Armed Status in UDM to show this?
@Jimbo.AutomatesI was.  I can select it either in IoX or UD Mobile but the only ones that work are disarm and the two "Armed Next" options.  The others flash like Armed Stay but then go back to disarmed
