Elk v3.80
After updating PG3x to v3.2.1 and reinstalling all of the node servers, I noticed there was an update to Elk v3.8.0.
After doing the upgrade, I noticed the version # on the Elk node server page was v0.0.0. I re-did the upgrade with the same result. I tried to sop and restart the node server with no change.
Solved by Jimbo.Automates
That's odd.  @bmercier any idea why it would show that?  With this release I removed the old server.json so it should get the version the new way now.
No I’m not sure why. I also don’t use server.json for Ring, and it works well.
Does the log tells us anything?
Not sure, I was going to test on mine, but just noticed PG3 isn't telling me an upgrade is available?  I'm on 3.7 and 3.8 is out?
image.thumb.png.7176e809b73fa4d4dbd9754279650956.pngimage.thumb.png.bf5dbccf7fd74b2516e9ca9cc2393467.png
I manually did a sync purchases, then it showed the update.  Now I have the 0.0.0 as well and log says:
2023-08-15 13:54:43,570 MainThread udi_interface.interface WARNING  interface:_get_server_data: get_server_data: failed to read file server.json: [Errno 2] No such file or directory: 'server.json'
1 hour ago, Jimbo.Automates said:
Version 3.8.1 released with the fix.
I completed the upgrade and it fixed the version number issue. After about 5 minutes of uptime, I checked the node server in the admin console and it was showing disconnected. I had to restart the Elk node server and no all seems fine.
Thank you.
