Purchase Modules-404 Error
In preparing for migrating my ISY994 to the new eISY, I thought I would refamilarize myself with what modules are available as I thought I might be able to use a weather module for some of the stuff I am planning on doing on the eISY.
SO.. on my isy994i, I go to Help > Purchase Modules and it opens a link with my UUID attached and it comes up with a fancy 404 error page. Woops 404 Not found.
Tried several times then tried on my other ISY994i and same 404.
Can someone advise me if modules are dead for the isy or just a temp problem on UDI's end? Are there any modules available for the eISY?
John
Solved by Brian H
@johnjces
The climate / weather module for the ISY994 was discontinued some time ago.
The EISY uses node servers for weather, cameras, etc. Once you're on the EISY you can access the node server store where you're able to purchase over 100 node servers
An example of the available node servers can be seen at the following link:
https://polyglot.universal-devices.com/
Boy am I behind the curve!
I knew and read that the iSY994 was discontinued, hence the upgrade to the eisy, but I sure skipped over the modules stuff.
Thanks so much for the replies and the link to the node servers available.
A lot of folks will be using the ISY for a long time I will bet as it still works very well. Wish UDI could make a static page if and when you click the Purchase Module instead of a 404 on the ISY.
Again, thanks!
John
One thing I forgot and may have had a effect on this.
You had to use the My Account choice on their site. To purchase and manage Modules. The old Modules choice in the Administrative Console no longer worked.
I just signed in to My Account and could see what each of their products I own and had for modules in that unit. From my ISY26 to both of my ISY994i and ISY99i.
https://wiki.universal-devices.com/index.php?title=Main_Page#Add-On/Optional_Modules_for_the_ISY-994i
Edited by Brian H
