Are multiple batteries consolidated into single instance?
GQuack
@bpwwer Greetings, our SolarEdge installation has 2 inverters, each with 1 battery attached. When I restart the node server, the log shows finding 2 inverters and 2 batteries, but there is only a single battery node with a node name of battery 1.5 and a single battery in the Polisy. Are the two batteries being consolidated?
2023-08-19 11:09:48,914 Thread-1   udi_interface      INFO     solaredge-poly:discover: Discovering SolarEdge sites and equipment...
2023-08-19 11:09:49,807 Thread-1   udi_interface      INFO     solaredge-poly:discover: Found 1 sites
2023-08-19 11:09:49,808 Thread-1   udi_interface      INFO     solaredge-poly:discover: Found Active site id: 1003126, name: Quackenbush1, TZ: Pacific/Honolulu
2023-08-19 11:09:49,809 Thread-1   udi_interface      INFO     solaredge-poly:discover: Adding site id: 1003126
2023-08-19 11:09:49,811 Thread-1   udi_interface.interface INFO     interface:addNode: Adding node Quackenbush1(1003126) [None]
2023-08-19 11:09:49,813 Thread-1   udi_interface      INFO     solaredge-poly:discover: Requesting site inventory...
2023-08-19 11:09:51,069 Thread-1   udi_interface      INFO     solaredge-poly:discover: Found: 8 meters, 0 sensors, 0 gateways, 2 batteries, 2 inverters
2023-08-19 11:09:51,070 Thread-1   udi_interface      INFO     solaredge-poly:discover: Adding inverter 7F177E6B-7F
2023-08-19 11:09:51,073 Thread-1   udi_interface.interface INFO     interface:addNode: Adding node Inverter 1(7f177e6b7f) [None]
2023-08-19 11:09:51,075 Thread-1   udi_interface      INFO     solaredge-poly:discover: Adding inverter 7F16EF1C-A0
2023-08-19 11:09:51,078 Thread-1   udi_interface.interface INFO     interface:addNode: Adding node Inverter 2(7f16ef1ca0) [None]
2023-08-19 11:09:51,080 Thread-1   udi_interface      INFO     solaredge-poly:discover: Adding battery R15563P3SSEG12204231694
2023-08-19 11:09:51,082 Thread-1   udi_interface.interface INFO     interface:addNode: Adding node Battery 1.5(r15563p3sseg12) [None]
Are you using the production node server or the non-production one? I created the non-production one but the logic for identifying batteries has not changed. i plan to move the non-production version to production but haven’t had time to do that yet. I can try to debug your issue but would need your api_key. If you’re interested you should DM me with that.
ken
      378.9k
