Thermostat Tab
io_guy
How about an additional tab/page in the admin console for easy configuration of the venstar thermostats?
Instead of setting up several programs referencing each other, there could be a single page that allows for 7-day 4-scene setpoint adjustment.
Michel,
The best example (and I appologize if I shouldn't be linking to other companies products - feel free to delete this post) is the schedule configuration page on the Bay Controls thermostat.
http://www.smarthome.com/manuals/3371W-1.pdf
If you look at the photo at the bottom right of the 2nd page you'll see a great example.
Basically a grid which you can graphically adjust the temperatures and times of where wake, leave, return and sleep sit.
If we had something like this for the ISY/Venstar I'd throw away my VisionPro IAQ and buy a T1900 tomorrow.
Hi io_guy,
No problem at all and no posts are deleted unless they contain profanity or pornographic contents.
This makes perfect sense for one thermostat but I must posit that if you have more than one thermostat, and if you want to control them based on a variety of conditions, this paradigm does not work.
I also agree that there should be a simpler way of adjusting thermostat settings. Although I do not guarantee anything, but we shall look into it.
Thanks so very much for the feedback.
