n8huntsman Posted September 8, 2023 Posted September 8, 2023 (edited) Since you can't toggle outputs in the ELK M1 directly, I tried to turn on Output 2 to test my siren. I made output 1 and 2 visible, refreshed topology in ISY and the zones appeared in the ELL module of ISY. However, when I turn output 2 on in ISY, the status updates to 'ON' but nothing happens. When I do this for Output 1, my indoor siren sounds. Only difference is Output 2 is set to voltage output in ELK because its a siren instead of a speaker. I was starting to think I had a wiring issue even though ELK wasnt reporting a a supervisory problem. Then I created a rule in ELK console directly to turn on Output 2 when I open a door, and it worked with no issues. What could be preventing ISY from turning on that output? Edited September 8, 2023 by n8huntsman
