September 11, 20232 yr Hello all, This release contains a new operating system upgrade, some enhancements to Zigbee, Z-Wave, and Insteon as well as some bug fixes. Important Note: The new 13.2 version of the OS is included and an upgrade will be attempted during this upgrade. As such, it may take much longer to upgrade your unit (especially on Polisy) and the unit may reboot during the process. Please do not unplug your unit from power. Instructions: 1. Backup your unit. 2. Please click on the using the Upgrade Packages button in the Configuration section of the Admin Console. Zigbee  - Support for Zigbee On/Off switch  - Support for Zigbee Occupancy cluster (required by some motion sensors)  - Basic support for Zigbee door locks (lock/unlock/query) Z-Wave  - Support .gbl OTA Firmware upgrade files  - Support abandon OTA Firmware upgrade Insteon  - Support dimmer/relay mode for I3 Paddle and I3 Keypad  - Support various flags for I3 Paddle and I3 Keypad General  - Support dynamic text status values for node servers  - Add parameter initial values for light on/off commands Bug Fixes - Fix: Some file updates were not synchronized - Fix: Zigbee Synchronize New & Deleted with Interview - Fix: Zigbee Color commands not available for some customers using Sengled color bulbs - Fix: Zigbee devices unexpectedly removed from network - Fix: WiFi gets disabled forever when Ethernet is plugged in Â
