IoX Remote Backup
I have an eisy installed at my second home.  I use UD Mobile and ISY Portal to access it.  I plan to remotely update to the latest version of IoX.  Is there a way to remotely backup the current configuration before proceeding with the update?
Solved by DennisC
Use the portal IP address and login using your portal credentials.
The IoXauncher is used by selecting add a d then entering the IP address of your portal device, which you can find on the portal.
Once logged in to the admin console, go to File Backup.
You can also find your portal IP from UD Mobile,Settings - System.
Brilliant Dennis.  Worked like a charm.  Thanks so much.
