SwitchLinc run a program
How Do I make a switchlinc (on/off not a dimmer) run a Program?  In particular I want to run the "Then" operation. The program has no "IF" condiions and no "Else" process.
Techman,
I will try that. I assume if I have two things a switchLinc and a button on a keypadLinc that I want to run the program then, I just or them togather as the if condition.
Correct,
IF
Keypad is switched ON
or
Switchlinc is switched ON
THEN
  Program run then (program name)
5 hours ago, Techman said:
IF
Status Swirtchlinc is ON
@barrygordon do you want it to run the program only if the switch is physically turned on? You might want “control” rather than “status”.  If using “status” then anytime the switch is “on” (by any means) the program would be true and run.
https://wiki.universal-devices.com/index.php?title=ISY-99i/ISY-26_INSTEON:Program_Commands#Control_vs_Status
