edwaud Posted September 19, 2023 Posted September 19, 2023 I have had an EISY up and running for many months now and it is doing everything I want it to do. Quite happy with it. Today I discovered that the error log has the same error repeated every second and multiple time per second. I have Firmware and UI both on version IoX V.5.7.0 The error I am getting is; Mon 2023/09/18 20:33:58 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>./FILES/CONF/root.DBU</name></u:GetSysConf></s:Body></s:Envelope> What is the error, can and/or should it be fixed and how? The log file gets enormous quickly. Many thanks for any help here. edwaud
Solution mmb Posted September 19, 2023 Solution Posted September 19, 2023 On 9/19/2023 at 12:45 AM, edwaud said: Mon 2023/09/18 20:33:58 0 -170001 <s:Envelope><s:Body><u:GetSysConf xmlns:u="urn:udi-com:service:X_IoX_Service:1"><name>./FILES/CONF/root.DBU</name></u:GetSysConf></s:Body></s:Envelope> Expand I was told years ago -170001 is an informational message. So I just ignore them. It would be nice if there was a log debug setting to turn warnings off and errors on as needed. Log formatting needs work too. 1
edwaud Posted September 19, 2023 Author Posted September 19, 2023 mmb, Thank you for your reply. It would be nice to know what information the message is trying impart. I will just ignore it. Thanks again 1
