 Programs go from enable to disable
when I do a EISY reboot or if doing an update of the packages, all of the programs go into disable and are not enabled anymore… that started after last EISY update...... so about a month.
Thoughts ....
Solved by DennisC
When was the last time you updated? This should have been fixed in v5.7.0.
Check your version of firmware and be sure to download a new start.jnlp after upgrading and to clear your Java cache before running the new start.jnlp.
Also, see this post:
